My Air Ride Build Log
S
shundal
NorCal
Thanks. It's actually been pretty straightforward so far. I'm trying to take as many pictures as I can of the process so that others will have an idea if they decide to go this route.
---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ----------
Unfortunately my neighbor did not get the bag spacer welded today. But he promised to get it to me tomorrow
S
shundal
NorCal
Come on Lee, you know how many parts I have sitting around that never get installed. This is progress for me haha
S
shundal
NorCal
Got the brackets welded. They will need to be cut down to size but everything fits together.
S
shundal
NorCal
Rear TBSS bags are here. I am going to do a test fit of the front today, get the height dialed in and just fill it with my compressor to see how it rides.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you wil like the rear tbss bags
S
shundal
NorCal
Tony I think you mentioned you can add a different fitting to the tbss bags? Like. 1/4 etc. how would you remove the connector that is in there right now?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Drill top and tap for 1/4 inch fitting. before you do that id just do the 5/32 to 1/4 apater see how you like it. Will lift fast enough
djscrubb
If you do the 5/32 to 1/4 adaptor close to the bag there should be very little lag I wouldn't risk messing up the tbss bags to make bigger port
S
shundal
NorCal
Ok thanks. I'll just try the adapter first and see how well it works.
Dnozgodlike
