My Drop Experience - 5 Months Later
crazycrew
Vacherie, LA
.i threw some helper bags in the coils and it changed the ride 100%...bags are like 75 bucks on amazon and are well worth it..i was going to do the panhard as well, but after the bags it rides how i want it too..
Hmmmmm! guess I'll need to try this!!!
Nickleahy23
Portage/Menomonie, WI
Looks good and excellent write-up :cheers: Unfortunately these trucks will still behave in accordance to the laws of physics so comparing a highly modified truck to a sports coupe weighing 3000lbs less will leave anyone with a sour taste in their mouth. I would highly recommend installing a larger set of sway bars (I prefer the eibach 35mm front and 32mm rear) as well as shorter end links for the rear sway bar.
As far as the bumpsteer is concerned installing some heim'd tie rods and a steering stabilizer are the best methods for reducing the steering issue but remember, these trucks are quite nose-heavy and the torsion bar front suspension isn't designed for excellent handling characteristics.
I would also suggest installing some airlift helper bags as they will drastically increase the ride quality as well as towing capability. Z71 Tahoe front bumpstops (gm part # 15153959) are also an excellent addition to improve ride quality. These torsion bar ifs trucks have no natural rebound like a well-designed coil spring suspension or even leaves so an excellent dampener in conjunction with a stiffer jounce stop will make the suspension much more responsive (though you are limiting the amount of travel from the front suspension).
There is a bit of trial and error involved in setting up the suspensions on these trucks, but they ride and handle quite well once you spend the time doing it correctly. Best of luck to you and we're all here to answer an questions you may have.
im trying to figure out what to do for my front..because the djm arms dont come close the the bumpstops...and i would like to have something, because like you said with the torsion bars its nice to have that extra support
Max
Mile High
Denver
How tall are your current stops? 1" or so? The Z71s are mad taller.
BOSS
The People's A D M I N
Dallas
Couldn't have said it better, it's an art and each indiv tahoe handles ever so slightly different too... it aint easy being low
WHITEOUT
Dont Hate-Appreciate
Phoenix
Great review bro. Good info
I just got a pair of those Z71 bump stops from Max. Can really feel the difference. There alittle taller then others, but feel much better to me. I need to trim mine alittle tho. Heres a pic
BOSS
Dallas
its their design that makes them so stable, like an upside down muffin and that lip is where the benefit is
Jasrancore
