My first Tahoe 2007 15k miles... Need ideas!!!!
F
Facefart0228
Here is some more pics of the driver side interior and the new head unit with the runs hours.
Don't mind the wires I'm currently working on the backup camera and hdmi to the back seat.
Have great day
20200113_091234.jpg 20200113_091209.jpg 20200113_091159.jpg 20200113_091009.jpg
F
Facefart0228
Thanks guys, I do feel very fortunate and my fingers are crossed still.
I will try and keep posting what I have done when I can!
Pretty sure it's an SSV and, with those hours and the mileage, it's like its only purpose was to make a few highway runs ever so often. Lots of PPVs/SSVs can have low miles, but they tend to have high engine hours from extensive idling. Yours has low miles AND hours. No DIC switches, no center console, no body molding and those wheels all point to it being an SSV. Cool score.
For the leveling kit, hit up Amazon. All they are is a spacer to go under the bottom of the strut mount or on top of the strut. Measure how yours sits now and determine how much you'd wanna pick it up in the front. Use a jack under the cross member to lift it 1", step back and see what you think then raise it another inch and have another look. You can get a 1.5" if that's what you decide on. Oh- measure from the underside of the fender lip to the center of the wheel, on the center cap.
I got a 2" lower strut spacer kit made from billet aluminum for $22 on Amazon. I used my own Grade 8 bolts. It's no longer available but here's the same but with better hardware included: https://www.amazon.com/dp/B00KOU2UYU/ref=psdc_15731761_t1_B01LWAI1QN
Here's a 1.5" one. I'd probably replace the hardware with this one: https://www.amazon.com/dp/B079L1NWX8/ref=dp_cerb_2
Other options with different sizes and seemingly good hardware, according to the reviews: https://www.amazon.com/Maxracing-Li...BCTGJ5KAC05&psc=1&refRID=G586C491EBCTGJ5KAC05
One example of 1" lift: https://www.amazon.com/MotoFab-Lift...pacer+lift&qid=1578975568&s=automotive&sr=1-1
Also, pretty much all of these SUVs will be lower on the driver's side. Sometimes it's an 1/8" difference, sometimes it's around 3/4". If it were me, and because these kits are so cheap, I'd get a kit of two different sizes to have a little more lift on the driver's side to level it. Or, if you have the means, get one kit that will lift the driver's side the amount you want and have the spacer for the passenger side shaved down accordingly so it's level.
Austin12
