My grill is loose...how do I tighten it??
DenaliAK
Colder than you
Alaska
My grill is rattling around and quite loose and I have no clue how to tighten it back up. How the heck do you get at the attachment points??
05Yukon23
Arkdelphia, AR
If I'm not mistaken, the part of the grille that goes around the lights has a clip in either side that snaps into the side. Also there are a few bolts on top at the front when you pop the hood.
Location of clips:
Bolts are under this cover:
05Yukon23
Arkdelphia, AR
I am not sure of your year... This would be for 00-06... Don't know if Denali would be different.
Gzes
the drifting 2dr
Wichita tx
try youtube buddy its ur freind. Just look up how to remove the grille and just tighteb it up from there
OHSIXX
Milwaukee
There is a clip on each side of the grille assembly by the headlight as shown in the pictures. There are also 2 screws on the bottom of the grille-one on each side--push your bumper cover down just a tad and you can see them or use a flashlight. There are also upper mounting points as well underneath that radiator cover. If your insert itself is loose....don't know what to tell ya as I believe it is held in with multiple tabs around the grille shell...
-J
mharders
Just outside of Seattle
It's held in by six mounting points as Jason said. 4 screw type tabs around the "center" grille and two on the far end by the turns/DRLs that clip into the frame. All you need is a Phillips screwdriver
DenaliAK
DenaliAK
Colder than you
Alaska
Yeah, thanks....those pics tell the story. I'll check it out more tomorrow. Sounds more like it's rattling near the bottom than the top.
As for Youtube: I'm an old fart and don't even think of looking on there for anything useful. I blame my 18-year old and his freakin' obsession with watching youtube videos of other people playing video games....(rolling eyes)
ADrake75
