My latest Adventure, update 7/11/21
bigdog9191999
bigdog9191999
sw michigan
so we also had a little debacle after a storm... a branch stripped our wires right off the pole. and somehow they pulled in the drive and didnt see them, and it fell throught the cracks and we ended being out for a couple days, over 24hrs longer than the rest of the area.
had to put this little guy to work.
bigdog9191999
bigdog9191999
sw michigan
our lines where old 3 strand copper, and in rough shape, so they replaced with new from the house to the road.
bigdog9191999
bigdog9191999
sw michigan
so, this became a hell of a thing. and the irony is i had set up a deal to buy a 10k from a friend and sent the money the very morning of the day the power went out. (on saturday) sunday it was hot and humid, so we decided we were going to take the cats and get set up in the camper for a day or two. we get set up and are running the generator on the camper and later near midnight we get a message that we may have power at the house, so she runs to check ( camper is at a buddies about 7 miles away.) nope, lines still down. then just before she gets back the generator on the camper quits running! well crap. so i try to fire it back up and..... dead batteries.... wtf. so at like 1am we load back up and head back home, as at least we have the small unit and can keep reasonable, as it was still very humid and crappy.
while at the camper i got some lights swapped out, so there is some goodness going there now.
monday she calls again as everyone around us have power, and the gal was like ok.. there should be someone there about 3pm.. about 3:30 we call back and apparently the ticket was never summitted and nobody was on the way!! so about and hour after the last call the trucks finally show and about 45 min later they had the new lines ran and back in business.
so here are some camper led pics
194 type on the left, and the panel on the right
the old bulbs, that have been swapped so far.
bigdog9191999
bigdog9191999
sw michigan
while the power was out i tried to get some things done, the belt blew apart on one of the mowers, not a fun time to change those in the humidity.
also got after our old mower some to get it running again. needed some engine bolts, steering shaft, and a couple little things.. need to get the switch fixed so i can put the doghouse back on.
got the corner of the barn cleared out in prep to get some better power to the barn.. as there is like no. 10 wire feeding it now and it will be getting upgraded to no. 2 so i can get 50 amp in for the camper and better in general for better compressor, welder ect. didnt realize i had as many space savers stuffed in the corner.
then i caught a candid shot of the wife waiting for our pesky woodchuck to show his face while she was grilling burgers for dinner.
bigdog9191999
bigdog9191999
sw michigan
and a couple of final thoughts for now.
they are finally putting the cap on our road they paved last year. which puts the total time from chewiing the old pavement to dirt. to being "done" almost 5 years!
jumped on the bike to come home and couldn't believe the random perfect number i had pulled into work on.
and a statement about rv fridges suck.... the cooling coil inside the unit is near icing up and the temp inside the unit is about what i would expect in a cooler with ice.
and to finish with the cuteness.
bigdog9191999
bigdog9191999
sw michigan
alright guys time for some updates again. got some big projects done, and a few little things to go on them. but is going well!.
ok so the short version is that we are upgrading power to my barn, for several reasons. many are just that i want to be able to have a better air compressor, and run a welder and such, but also i need 50a rv service, so i can run the full camper. as her mom is supposed to live in it for several months at minimum till we get her new place built ( after her current place is sold) but so we can power things up on our own also. sooooo
for those that dont know, we are simply running big *** wire to power everything correctly. for those that do know we are putting in 100a service from our main house box to the barn ( had some 10/2 powering the whole thing as they originally just wanted a few outlets and some lights.) we are putting in 2-2-2-4au we got enough of the mobile home feeder to go from house panel to barn and got a quote for $2,400 to have everything but the trenches done (we were gonna have to do that part still. ) after looking closer at how it was going to need to be in the basement to make code (consulted my bro in law that is a commercial electrician, and i wanted to be at least damn close to code just so that if something ever happened that there would be little issue with insurance ect. ) and looking at cost it was gonna cost marginally less to buy just the pvc conduit to run this wire in ( it is direct bury, which means anywhere it isnt in the ground it is supposed to be in conduit or similar). that we could get wire that could be exposed and would be about 1000x easier to run across the basement. so we ended up getting even more wire, we also decided that where the camper is going to be that we wanted power at the pole that is at the corner of the patio, and that the pole should be replaced, so we got that also.
and found this cool old beer hiding down there also, the new outlet and cover is were i was moving some things to prepare to run the wire and the outlet shorted out, so i had to move some things and replace that on the fly, and is when i found the beer.
bigdog9191999
bigdog9191999
sw michigan
the real fun bits
i fixed the wire, this was just tossed in there so we could close the other leg, while waiting for the big wire to go in.
also had this little chipmunk come and give some pissed off attitude about doing all this work.. he was running around chittering and showing his distained for our activities.
bigdog9191999
bigdog9191999
sw michigan
got the inside wire ran, and hooked to the outside wire.
and i just had to color cordinate and taped even though i didnt really need to i did the ground just to give some extra that the connector will not come loose.
bigdog9191999
bigdog9191999
sw michigan
also found some not good things when i got the old wire out. had been wet and the old friction tape was rotting away. and this was still working!!!! kinda scary!!
bigdog9191999
bigdog9191999
sw michigan
replacement panel i picked up from my neighbor,
the tiny thing that had been in the barn
replacement and new backer on
all wired up for now. have the 50a rv and 50a gen plugs, as well as a good 220 plug to add for welders or whatever.
also finally got the gen at the house.
Roscoe2352
