My onstar is to old
Teachme
Ok my 2000 tahoe has onstar they said its analog and needs to be replaced. Has anyone upgraded theirs and maybe even headunit upgrades to.
Sent from my transforrm ultra !
91RS
GA
You can only upgrade it through the dealer becaus it has to be installed there and programmed.
Alex33
Any OnStar system before '04 can't be reprogrammed. There was a 6-9 mo overlap where the digital and analog systems were sold together. Vehicles sold in that period can be brought up to date with a reprogram. Vehicles before that cannot be switched over to digital unless an updated brain is installed. The update was in the neighborhood of a few hundred dollars a couple years ago, not sure what it would cost now. The new brain is something like $5-600 and then whatever the dealer would charge to install and program.
For additional info, contact your dealer. They'll have a bank of VINs for vehicles that can be re-programmed. If your vehicle isn't in that group of VINs then the switchover will require new hardware.
Wake
Stafford, VA
If it's onstar you want, how about this?
http://www.bestbuy.com/site/OnStar+...06&skuId=9999179800050006&st=onstar&lp=1&cp=1
I see it go on sale occasionally for $100 with installation
Or maybe look into fitting a newer onstar unit into your 04. It should be on the class II data bus so I think it should work. I had on 02 Trailbalzer where navigation wasn't an option until 03. I transplanted a nav unit from an 05 Escalade in it and away I went. Anything that was from a class II data bus was transplatable. You might be able to find one on eBay cheap from a wrecked vehicle.
ericjvasil69
