my radio
qukon 95
qukon 95
thats because they have power hungry amps so the batts
need to keep up with the demand and the multi alts charging the same batts will keep the voltage at the max.
I don't have a need to run my alts that way, no power hungry amps in my system but i can have 2 separate charging systems under the hood with no voltage problems. Runnning amps at 1 to 2 ohms require max voltage constantly than amps loaded at 4 ohms like
my system. I hope this cleared it up for you:Rock on:
juggernaut26201
you can have 50 alternators charge the same battery if you want as long as the alternator's are charging at the same voltage. my question is where did you get the daul alternator bracket? i have a 98 tahoe and i cannot find a prefab dual bracket anywhere, unless i take out the ac, and that is not happening
tators50
