My Yukon broken into
WoldD90
WoldD90
Off Road Addict
Atlanta, GA
u can also put a rear door handle in the front door so there is no key hole in the front door
I like this idea... I have two batteries, so it would not be as much of a concern. I will probably also install a separate alarm with glass breakage. I may put a siren inside as well as outside.
My Range Rover has a superlock feature, that you can not get into with out the coded key or the remote. If you break the glass it has an internal siren that is wicked loud.
alsalt
