NathanJax's 2007 Yukon Build
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you dont have the djm rear hardware kit in there huh. I can see how tires are sucked to the front of the truck.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
rub it in Tony... rub it in...
Within the next week or so I'll be taking care of it.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Front - 32.75 inches - Belltech 2" drop spindles & Belltech drop struts
Rear - 34.5 inches - Belltech 5323 Springs and Belltech shocks
Going to have to raise the front up a bit. I can't turn without major rubbing. I also want the rear to come down another inch. It's the difference in the 5305 (which I need) and the 5323 (which I have). I'll be ordering the rear kit and the 5305 springs in a week or so. Going raise the fron up a half inch or inch till I stop rubbing as bad. I'll also be heating the plastic, but heating it now won't help at all...
Administrator
Looks nice!!!!
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
So I need 2 new tires anyways, so I'm going to do 295/35/24 for the front 2 tires instead of 305/35/24 and raise it just a hair, up to 33" and see what happens...
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Haven't updated it in a little while. I got the 295/35/24 tires up front, still a little rubbing, but I'm waiting for my 5305 springs to arrive to finish up the suspension. Then I can cut/trim/heat the areas I need to.
Also bought:
DJM Rear Hardware kit (Trailing Arm Relocation Brackets,Shock Extenders, and Swaybar Shorter Endlinks)
Air Lift Rear Air Spring Helper Bag Kit #60769
Belltech Front Camber Kit
And since I'm almost done with the outside, it's time to start working on the inside...
yates ™
Resident Apple hater
Iowa
Looks like someone is going to have a busy weekend.
Juggernauting
