Bigbird
What happened to the old easy to use Nav system?
Not impressed with Google Maybe when I get used to it
Anyone have tips?
Anyone have tips?
you don't have voice command?What happened to the old easy to use Nav system?
Anyone have tips?
It took me a while to get used to the new system too but it actually works quite well and will even show speed traps on route. The easiest way I have found to save "favorites" is to put them into Google maps on your phone. When the phone connects, they magically show up as favorites on the GPS.What happened to the old easy to use Nav system?
Anyone have tips?
To the maximum extent possible I have deleted all things Google from my vehicle. Simply use Apple CarPlay. If time is important to you, the Waze navigation system is the best. After that, the Apple navigation system is next. DEAD LAST, IS GOOGLE MAPS.What happened to the old easy to use Nav system?
Anyone have tips?
I have a 23 Yukon Denali and I've been having problems with the GPS using it directly on the screen and via my android. 1 out of 10 times the phone won't hook up or the GPS thinks I'm 2000 miles away or not hook up. Hit the ONSTAR button and get someone in technical linking. I spoke to Jennifer today and she literally had me redo the phone and car settings where no one would take the time. After 45 minutes I finally works great.you don't have voice command?
Good infoI have a 23 Yukon Denali and I've been having problems with the GPS using it directly on the screen and via my android. 1 out of 10 times the phone won't hook up or the GPS thinks I'm 2000 miles away or not hook up. Hit the ONSTAR button and get someone in technical linking. I spoke to Jennifer today and she literally had me redo the phone and car settings where no one would take the time. After 45 minutes I finally works great.
Also she removed permission for the dealer to see my truck via wifi. Appairently this part of the program can cause hiccups.
