NBS rear bumper removal?
Narco
Atlanta
Ive searched and checked the Chilton manual and cant find directions on how to remove the rear bumper. Can anyone help me out?
94z28guy
6 Bolts,
2 on each corner bracket.
2 in the center tnear the hitch.
taylorjm
Saginaw, MI
I thought there was a lot more than 6 bolts. The ones you mentioned plus the 4 on the little tabs on the top of the bumper, which makes at least 10. If you have an impact, extensions and universal joint, it makes it a whole lot easier. I wouldn't have even tried on my 03 without them. Plus, the bolt heads are round, so you need to hold them with vise grips once you start to remove them. Still, it's not hard, but highly recommend an air impact, and maybe a helper. (not recommending the wife who's only job was to hold the vise grips, but screamed everything time I pulled the trigger on the impact)
Narco
Narco
Atlanta
yeah, i crawled under and looked and if i recal there was at least 4 bolts on each side
02YuNali916
Sac, CA
i took mine off a couple months ago, not hard, i think there was 8 bolts each side, i didnt use air tools but i did need a breaker bar, u mite need someone to help u slide it out
Narco
Narco
Atlanta
going to my buddy's later who has air tools...ill let yall know for sure and post pics
Narco
Narco
Atlanta
id be even better if i knew what size bolts these are...ive tried every socket ive got and cant find a match
SunRae48
