- Joined
- May 3, 2009
- Posts
- 3,720
- Reaction score
- 5
Well it would ride like a 3" taller spring until it bottomed out. The reason for the stiffer springs is because of the restriction in travel, not physical limitations.
You would still need to cnotch it if you were gonna try to hammer it... i wasnt addressing the clearance issues as much as the limitations of room in the "spring over axle" setup.. by using different mounts and creating a lower profile mounting situation you allow yourself to run more spring.. so you get a better ride.. clearance issues are clearance issues..
The ability to run a 5 inch drop spring and get an 8 inch drop.. or even a stock spring and ride to get down 3.. is just a comment on the physics of spring height and how they could be used in a different way.. as opposed to all of us wondering how to run a smaller and smaller spring.. using the spring to our advantage and modifying the mounts...
You are right though.. running a softer spring to get down 5 as opposed to the stiffer 5 inch drop.. could create a situation where axle to frame issues COULD be more prevalent.. even with stiffer shocks.. but.. im assuming anyone who went though this amount of fab to get an extra few inches and abetter ride out of it.. will probably do a cnotch and alleviate the clearance situation right from jump...
