Need a new radiator
T
Tamcphail89
Thinking I'll go with 1800 radiator. Should have the oil and Trans cooler lines?
adventurenali92
Big Bear Lake, ca
verify when you order with the rep on the phone that the 1800radiators unit will have the fittings for the cooler lines to attach. Mine had them but I forgot to ask until physically got there to pick it up. But it will not have the lines themselves. I asked about that, even though I didn’t need them, just to know what was coming with the unit. You’d have to order those separately from another supplier.
T
Tamcphail89
So the top one? That's the rpo code I have
KCpm
OE, it lasted this long, it'll go the distance again. If you search the threads, you will some fairly recent posts with Mishimoto radiators and some others that are well thought of.
Hi, I plow,,, had an 05 suburban, went threw 4 radiators in 80k,,, said next time I would go aluminum,, sold truck, got a 13 Tahoe, that already smelled like antifreeze, so put a Mishimoto, $500,,,, looked mint, fit mint, plug and play,,, 3 core,, it's ben 6 months, so far so good ! gets up to temp almost as fast and maintains perfect,,, and if it leaks, I can get it fixed,,,,,and I didn't see this anywhere,, but I put a 7.5 fisher SD plow,,, took a little, to figure out the right parts, but works great, I wanted a trip edge, not trip blade,, just plowed over 12",,, I love my new truck !IMG_0056 2.jpeg
Hi, I plow,,, had an 05 suburban, went threw 4 radiators in 80k,,, said next time I would go aluminum,, sold truck, got a 13 Tahoe, that already smelled like antifreeze, so put a Mishimoto, $500,,,, looked mint, fit mint, plug and play,,, 3 core,, it's ben 6 months, so far so good ! gets up to temp almost as fast and maintains perfect,,, and if it leaks, I can get it fixed,,,,,and I didn't see this anywhere,, but I put a 7.5 fisher SD plow,,, took a little, to figure out the right parts, but works great, I wanted a trip edge, not trip blade,, just plowed over 12",,, I love my new truck !View attachment 266146
yer getting showed up @Galante
PG01
Up here to the right
I am in the process of ordering a set of front timbrens... helps with the dip when you pick it up. Had them on my 01 tahoe. That truck didn’t squat at all when I raised the plow.
T
Tamcphail89
So I'm trying to figure out what else I need for my radiator install. I know it's leaking at the bottom drivers side of the radiator and the hard line that connects into it. It's green so I'm assuming it's not transmission line correct?
Driver's side lines going into radiator tank are for the engine oil cooler.
TahoeInterceptor
