Need help debating new wheels
dcyy
I love the optional OE 22" wheels on our 2012 Denali, but.....after replacing 2 already, I have the other 2 leaking air at the bead, forgive the dirty wheels, been cold and nasty here.
Maybe if I can find 2 more I will keep them, but they aren't cheap, IF I can find them. Bead sealing can only go so far, these haven't been sealed yet, but I have an appointment tomorrow to assess the damage.
If I could find a 20" wheel with a similar style, I might go that route when these tires wear out. So I'm curious to the options of preserving the bead and not having the chrome flake off as these are still in good shape. Or....replacing all 4 wheels with a chrome finish that is a polished finish and not plated.
I would like to preserve the look of this vintage of Yukon as much as possible, but open for options. I'm not really a fan of the OE 20" Denali wheels, they aren't bad looking, but want something similar to my 22"s. If anyone has dealt with this please chime in.
My last 2 Denali's had factory chrome wheels and never had any problems with bead leakage. Dealer filled tires with Nitrogen which basically is a drying agent-prevents moisture build up inside tire
my original oem chrome wheels are now 13 years old and they are perfectly fine, never have had a single issue
even if the bead get's funky all you generally need to do is polish it any competent wheel shop can do it as well
petethepug
Michael
SoCal
My chrome 22’s leak 2-5lb a day if they’re not prepped correctly.
The chrome on the beads is inferior on the OEM Esky Plat rims. Once they’re descaled and installed with some kind of black gooey sealant, they’re good.
flipharvey187
All you need is to take to a good tire shop and have tires removed and then the wheel cleaned with a wire wheel or light grinder to get the corrosion cleaned up so the tire will seat to the bead properly... if they aren't bent or cracked then they will seat to the rim properly... those are actually in really good shape... no reason a good shop can't get them to stop leaking...
Sir_Hiro
I'm planning on actually Downsizing my 20s to 17-18s because of Cheaper Tires and I want a bit more Sidewall to Wheel Ratio. Give it a more meater look
SkyWalk3r
