Need anything for New LED Tails?
mizzouguy
Lake of the Ozarks, MO
Looks right to me, top is two wire for turn and ground, bottom is 3 wire for ground, brake, and tail. Assuming it uses fancy wiring inside to alternate brake and turn properly, you should be good. Kind of like a converter for trailer brake lights.
easterr
I have the Spyder brand that look just like the lights in the link provided by Sasquatch. Very good quality for an aftermarket light and plug and play. Got them on Amazon warehouse deals. Very happy with them and makes the Denali look 5 years younger. :)
Hyperion
Are these true plug and play as in it the housings have the same plugs as the OEM and you just unplug the old and plug in the new and you're done? If so I'm grabbing a pair.
easterr
if your question is directed at me, then yes, the Spyders are true PNP. You remove the bulbs and the lights wires have connectors that resemble the a bulb connection, which is plugged into the truck's bulb connector/wiring. There are youtube videos.
Hyperion
Awesome thanks. I'll be looking those up and grabbing a set to replace my dated and starting to wear tail lamps.
easterr
Sure thing. Check out the videos on YouTube or the eBay auctions. One of the wires (the brake wire, I think) is a bit short. I just sliced some of the wire loom, which provided a little slack, really not a big deal at all.
Yeah I would go with Spyders instead of those EBay no-brand ones. I really like mine.
kwOH
Banned
I went with the spyders because on the ebay ones the whole light flashed when the turn signal is on and with the spyders only the lower half of the leds flashes, guess it depends on what u want tho.
mikefdny
