Joseph Thomas
I have a 2011 Chevy Tahoe LTZ with a 5.3 and it has just over 122,000 miles. I noticed that there was an issue a few weeks ago when I had the heater on, and it was set to 75 degrees. It was blowing warm for about a few minutes, then it turned cold. I then turned the heat up to 90 and it blew nice and hot. Then turned it back down to 75 degrees. It blew warm for about a minute or two and then started to blow cold. I check my coolant system and the fluid level seemed to be fine. The overflow tank was at the Max fill line. I inspected the radiator hoses, and the heater core hoses. Both heater core hoses are hot. Both radiator hoses are hot. The top radiator hose has pressure, and the bottom radiator hose has no pressure. My first thought was the thermostat was bad, so I replaced the thermostat. The issue persisted. Then I thought since maybe the pressure was an issue, I replaced the overflow tank cap. Still no fix. I inspected the vehicle all around it could not find any leaks. I then checked the rear heater hoses to make sure if that system was it compromised. Both rear heater hoses are hot and again there are no leaks. I went ahead and flushed the heater core even though I do not think it's clogged because both heater hoses are hot. After I completed this there still is no pressure in the system and I am still losing heat. I went to O'reillys and purchased another reservoir cap just in case the one I purchased before was a bad one; It was not. I then and rented a pressure tester and tested the system. I pump the pressure up to 20 PSI and let it sit there for 10 minutes. The system retained pressure. Both top and bottom radiator hoses were hard, and I could not squeeze them. Now this does not make sense. How come the vehicle cannot create pressure on its own and retain it, but when I put pressure in the system with a pressure tester, it will maintain proper pressure? I'm wondering if it's the water pump? Still I have no leaks . I'm not losing any coolant anywhere. I can't find any moisture around the water pump or where the weep hole would be. Anybody have any answers to this issue? Also, there is no moisture from inside the passenger compartment floor that would indicate the leak in the heater core.
