Need help breaking down on road trip
2Canoes
So I guess the rear end is going out? Only pulls with the front wheels?
G
gore666
I'mthinking that or the tcase I think if it was the tranny it wouldn't matter 4x4 or 2x4
ScottyBoy
Shreveport, La
Mine did pretty much the same thing. It was the spider gears in the rear end, they stripped out and then took the transmission with it. It literally shattered the sun shell. I was able to limp it home 20mph in 2nd gear. Ended up needing to get both my rear end and the transmission rebuilt.
Sounds like your rear end is shot, and the transmission is on its last leg.
Good luck. :Handshake:
G
gore666
Made it home we drove a little over 1000 miles in 4x4 I called the local salvage yard and they have a tcase for 400 and a rear end for 500 ill call the local transmission shop to see what they would charge for rebuilding I'd much rather go that route so I know what I got
G
gore666
With the truck in the air and tranny in neutral everything cold it spins smooth but tcase screeches as it spins. There is some play in the rear end I'm not sure how much is normal. I took a small drive and it ran fine no problems. I put it back in air same thing but the screech was almost gone I put the tcase in 4x4 to see what happens and it just turns the other wheel like it should but there's a very tight spot where I have a very hard time spinning the wheel then it loosens up again is that normal.
Edit
I just did the same thing with my truck and its way easyer to spin and it spins the other wheel backwards. The tahoe spins the drive shaft not the other wheel. I did something dumb but I did it safe lol with them lifted I put them in drive and stopped one wheel with the tahoe it would stop then slam and start spinning when it did this the other wheel would stop for about half a second then start right back. I'm thinking that's limited slip in action but not sure my pickup didn't do the same it just let me stop one wheel and didn't try to get it to move its a 99 2500 if it makes a difference. Next drive I take I will take a temp reading of the rear diff.
Another edit took a drive and it did it a few times I pulled over and set the brake the drive shaft was shaking and the tcase grinding. Did this same thing in reverse as well. Also tried 4x4 low and it try's but won't go
Firefiterp
