need help I'm steering column issue
germantown tn
steering wheel problem
I was involved in a wreck awhile back and due to it was forced into the steering wheel pretty hard an now months later it's wobbles everywhere I've searched and all I could find was info about the ISS problems on these trucks. I was wondering if anyone knew anything about bearing in the upper part of the steering column? any help is greatly appreciated!
B
germantown tn
08grey
Google steering wheel clunk. They sell A new shaft improved as the old one wears very easy.
B
germantown tn
it's not the ISS this an upper bearing issue I have a new ISS already just can't seem to find any info on this bearing. I can pull the wheel in and out about a half once and it's wobbles around like an inch and a half either direction side-to-side or up and down
B
germantown tn
tore it apart and found the issue. the part was called a housing seat. was right behind the bearing before the spring. it has crushed an was causing the slack
lpadron1
