Need help with dual amp install
V84x4
Coming out Large
Just installed my 1oooW mono & 1oooW 4 channel
And my battery died in a week so i just bought a "Red Top" "Optima"
and it's all better now
future plans for second "yellow" top Optima just for my system
SVTAddict03
I don't have a factory amp. Mine didn't come with the bose system or anything..
Already bought the amp, and everything. It's just sitting in a box right now..
What's the "big 3" ?
You should have a factory amp. Mine doesn't have the Bose system and still has factory amps. Mine is located behind the glove box.
YukonXL04
The Riverboat
Arlington, TX
Not true. some have them and some don't. Mine is a 04 without Bose and I don't have a factory amp.
Also Just because your amp has 80A worth of fuse, doesn't mean it will ever actually pull 80A. Majority of the time you are looking more like 40A. Unless your at bass comps with it cranked way up on short bursts. Playing test tones and such then yea your going to be more in the 60A + range. And your 4ch will hardly even pull half of its fusing.
When installing the dynamat in the doors make sure to cover up all of the large holes in the metal. your goal is to truly separate the front and rear waves of the speaker.
As far as capacitors go, don't bother with them. spend the money to run larger wires lol. with your current amps you can easily run both of those off a single 4ga wire run and split of to 2 8ga to the amps.
03chevyhoe
No need for a bigger alternator. i have 1500 watts in my avalanche and just have a kinetic hc1800 battery and big 3 and have no dimming. just use 0 gauge for big 3 and you should be fine.
harlamert
