need help with wheel size asap
B-ROCK
BC, Canada
TXGMC those are sick! if i'm reading this correctly, you're running 33's with only a small crank and rear blocks? any rubbing issues? after seeing your pics i'm worried now that the tires will look small if i go up 4"
I'm in the same boat as you. I want to run 295/76r16's with a 4 inch lift. The tires work out to pretty much the same size. I've seen pics with this set up that look good and some that don't (tires look small). Check out Hapyspaz's tahoe. He's got pretty much that set up and it looks great.
Dumb question- If he got the 4 inch lift and the tires looked to small can you turn your torsion bars down ???? Like I said....dumb question.
99_2door
omaha
you could but what would you do about the rear? it would be sitting higher than the front.
99_2door
omaha
i dont see why that wouldnt work. i'm going to just go ahead with the rcx 4" kit. hopefully it sits level or i'm going to have to do some cranking.
bowtiefreak
No Quarter
Near Philly
The back is easy to change. Do the front, figure out how much higher you need to go and get the AAL or block to fit. Remember, do not re-use the stock U Bolts.
iaminfiji
