Need picture of headlight switch with OEM fogs button...
kbuskill
NE. FL.
I'm not sure I understand your question Dario. As seen earlier, I'm having reading comprehension issues! LOL
Which switch?
He is trying to figure out which wires (for fog lights) he is missing in his PPV dash harness that plugs into the back of the headlight switch.
So he is looking for the pin out of the plug on the back of the headlight switch in the dash.
The pin outs you posted appear to be for the transfer case shift control module.
They are, so he wants the same thing but for the light module?
How about this one? It's the plug end.
GranPrix
GranPrix
Update. Since the switch is a grounded system I figured I would try installing the activation wire for the fogs parallel with one of the headlight switch functions. Since most of the pins are always hot except for the black ground wire (#8), I wasn't getting any luck until I tried pin #7, the brown/white wire. It's the dimmer switch! LoL
So guess what my fogs are capable of doing now?? They can go from full on power to 3 lower dim settings then off. But they only come on with the park lights/and/or headlights on. The dimmer switch wont turn them on unless the park lights are on obviously since thats when your instrumentation would be on.
drackill1
