Need some advice on which direction to go
iboughtatahoe23
iboughtatahoe23
No the black ring next to it around the cable with the black/pink plug.
Yea it plugged in, took it to my mechanic and he said it’s fine. Put a really nice reader on it. And no codes other than some communication codes in the electrical stuff(not relating to the engine)
Did some voltage tests on the battery and alternator. He said those check out too so. I guess I’ll just keep an eye on it when i start it in the mornings
houstontaylor
Maybe injectors are leaking overnight into the cylinders which would give a quick start at first and then a pause until the fuel pump fills the lines back up to pressure. I think mine was doing that one time. You could do a pressure test on the fuel supply line above the engine and see how long it takes to bleed down with the engine stopped.
Josejr00
