need some help quick!
W
WhiteHoe.
There's a guy on this forum that has the same wheels and the same thing happen to him but I dont remember what he had to do to get it to stop shaking
---------- Post added at 06:43 PM ---------- Previous post was at 06:41 PM ----------
His names tntahoe
fire730
Louisiana
Yes it is a special balancing machine that puts a load on the tire while it is spinning to simulate the weight of the vehicle on the tire.
Did you ever look to see what the hub or center bore of the wheel is? That makes a big difference on how much anyone on this forum can help you without physically seeing the truck.
W
WhiteHoe.
well i got them roadforced today and didnt help much. if at all. asked about hub rings they said they dont need them. the bore is correct.. now what the hell do i do? tie rod ends or something?
bottomline2000
Dallas, TX
check your wheel hubs. make sure they are good. doesn't matter how well the wheel mounts to the hub if the hub is bad. jack up the truck and shake the wheels. bigger wheels are going to put even more stress on them.
fire730
Louisiana
Jack it up under the control arms and grab the wheel and shake it up and down just like you are checking the ball joints.
Capeles
