Need Tire Help
h0tr0d
Brenham, Tx.
no crank needed. used that tire size on 3 different OBS.
If you run a 285 on the rims in your sig pic you're going to rub without a crank. Basically anything other than a stock backspace you're going to rub with 285's. TXGMC's setup looks badass but be prepared to do some clearancing for the 295's like he did cutting the valance and maybe the bottom portion of the front bumper.
The setup you posted should work fine and look sweet, but you'll probably have to crank around 2" in the front to keep from rubbing.
I wouldn't go any higher than the 285's unless you're prepared to pull out the sawzall.
PH99TAHOE
Janesville, WI
I have the Bridgestone Dueler A/T Revo 2 on my truck and they are very impressive. They dig pretty hard through the snow, I was able to keep it in
2wd and keep the truck at highway speed through 4" of snow this past winter. IMO the best bang for the buck.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
When I put my BFG All Terrains on, I didn't crank the bars and they did not rub. Granted that was on the stock rim. If you go after market chances are you will have to crank. When I put my Mickeys on I had to but no where near 2". Just keep in mind, the farther you crank the bars, the more stress it puts on your suspension parts.
smrr1
hotrod- ya i didn't realize he was running aftermarket wheels. i had my current 285s on an aftermarket wheel and had to crank so i went back to factory wheels.
TruckBoss223
TruckBoss223
Island Park, NY
I have no problem cranking the bars i want to anyways i just cant pick a damn tire
bowtiefreak
No Quarter
Near Philly
From the guys I have talked to the goodyears are ok, bascially every option in this thread is pretty good.
Devious_Tahoe96
Mr. Budwieser
West Texas
I ordered some mickey thompson mtz's that im supposed to get today or monday. I'll let you know how they handle :Handshake:
On a side note, isn't a 295 tire equivalent to a 33" tire??
tony97218
