Good idea!Time moves slower on the inanet Sir!!! He should probably start counting end of this month just for good measure
![Yaoface2 :yaoface2: :yaoface2:](/styles/default/xenforo/smilies/yaoface2.gif)
Looking at the timeline of events. Ricky posted one time and forgot he even posted!!@ hahaha!! Does the Denali even existGood idea!![]()
Another one post wonder. Why do we even try?Looking at the timeline of events. Ricky posted one time and forgot he even posted!!@ hahaha!! Does the Denali even exist
Is it possible he logged on and saw answers and just never responded?Another one post wonder. Why do we even try?
Well according to his stats he joined April 30th 2021 and was last seen April 30th 2021 so I’d have to say probably not.Is it possible he logged on and saw answers and just never responded?
Well according to his stats he joined April 30th 2021 and was last seen April 30th 2021 so I’d have to say probably not.![]()
I have a 03 Tahoe w/z55 option. I bought a resistor kit on ebay for like 12 bucks 2 kits for all four. I'm doing my front and installing the kit. For the back the coils have to be upgraded, then fly at it. Good luck.I’m new to the suv game my f1shitty decided to give up on me so I went out and got an 05 Denali I was wondering should I go with a 3 inch suspension or 3 inch body as I’m in hs and low on money I also want to know what I should do to the exhaust
please an experts on these cars lmk
Yes. You can also have the Z55 in use simply by making your own links for the ride height sensors. Just unscrew the ends, add lengthened rods, screw them back together and reinstall. I’m lowered 4” in the rear and still have the auto level in use. I made shorter rods. It’s great for towing. It also maintains the stock feel of the suspension. It’s up to you. If you eliminate the air shocks in the rear you need to change to the Z71 springs because the factory shocks help hold the rear up and the springs are too soft once the Z55 shocks are removed, as well as spoof the system by adding resistors.@S33k3r @Rocket Man @blueinkd So as to not waste your time and effort I will jump in because this kind of falls under something I am considering. I have an 06 Yukon Denali XL with Z55 and wanted to put a lift under it just to improve some approach and departure angles when I go off the beaten path. I have the 20X8.5 wheels off of the Sierra Denali and stock, 275/55-20 tires. I plan to go up slightly on the tire size, also improve clearance, but want to keep the wheels.
I need to replace my Air shocks in the rear and was thinking that this may be the time to look into the lift. Every lift I look at basically says w/o Z55. So my question is, if you remove the air suspension can you utilize the lifts that are to be used for trucks w/o Z55 or does it have different mounting points?
