donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,560
- Reaction score
- 2,775
I disagreeYou need new rear springs too if you delete the system
I'm just going by the amount of rear end sag I've seen after people delete the air shocks.I wouldn't say need. The springs for the ALC-equipped models are only marginally softer. I'd let his frequency or weight of towing/cargo carrying determine this. Otherwise, I'd get some quality shocks and enjoy the more compliant ride.
My Z55 rear shock air bladders have been bad since we bought the Denali 5+ yrs ago. Doesn't sag and rides like a dream.I'm just going by the amount of rear end sag I've seen after people delete the air shocks.
great information, thank you. Stepdaughter won't be towing or carrying heavy loads. you mentioned installing some resistors. where do you install them? Thanks again for the help.Yup. You have ALC (Auto-Level Control) suspension and those air sleeves on the shocks are deteriorated. The usual chain of events is they wear through and leak and the compressor runs more than necessary. The leaks get worse and the compressor eventually runs itself to death. You can replace the shocks and compressor and it'll probably pick up where it left off. OEM shocks, if they're even available, will be really expensive. An aftermarket compressor unit is about $200 last I checked. The shocks have electronically variable valving in addition to the air sleeves. Most, if not all aftermarket shocks that have the air sleeves bypass the electronic valving with a built-in resistor. So the aftermarket shock will connect just like the original with the air and electrical connections, but the variable valving portion won't be operable. The resistor is there just to keep the StabiliTrak and Traction Control Systems happy.
So, if you don't or rarely tow, or don't tow or carry much weight, you can disable the ALC system by removing fuses and install some ~$12 resistors to bypass the other systems. Then, install whatever quality "dumb" shock you want. Bilstein 4600 series are pretty much the #1 choice for this. Lifting or lowering will alter your shock of choice, if either of these are in your plans.
Yeah, I'm just different i guess if I'm going through the trouble of changing shocks might as well throw some springs in there for an extra $60 for the z71 model springs. I'm already going to be dirty and cussing at the car so might as well lolMy Z55 rear shock air bladders have been bad since we bought the Denali 5+ yrs ago. Doesn't sag and rides like a dream.
We don't tow a trailer with a lot of tongue wt.
