New 26s.. DUB FUTURES
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
there is a inner metal liner you should be able to use my 2x4 mod and turn tire and will push it back. take plastic liner off you will see it. yiu can also cut the metal liner out and put plastic liner back in.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
place 2x4 on back of tire
turn tire and 2x4 gets sucked into femderwell and pushes back the metal.
RotaryMachineRx
Saskatoon, SK
Haha, simple enough, this is for the front of the vehicle behind the front bumper?
---------- Post added at 01:55 PM ---------- Previous post was at 01:41 PM ----------
Nvm, I got ahold of my body shop guy and talked a little more in depth with him. I guess he'd been gone to some seminar all week so I wasn't able to get ahold of him. Now that I did and we talked he said he wasnt sure if it was going to hit this fender brace (where the front fender meets the bumper there is a support that connects to the rad mound to support the fender) and he just didnt want to tell me that every thing would be perfectly fine. He says worst case scenario may be some rubbing if I have the wheel fully cranked and I hit a bump or roll over a hill with some speed.
I feel much better about the whole situation now..... and yet spring is still sooo far away :(
oc714
Well just went with 295 30 26 Delenti tires. Damn the ride is harsh on 26's. Scary to drive it on speeds of 40mph+. Sure need larger brake kits and good suspension (stabilizer bar?)
Steering wheel started shaking at 50mph so I brought it back to get them rebalanced.
Guys here said they put on too many weights and will switch to American weights?? Let's see what happens.
08grey
Brand of tire and tire pressure matter on ride quality of 26"
oc714
It feels somewhat better on the street. Haven't gone on the fwy yet.
They are new Delenti tires and at 40psi
They said one wheel needed lots of weights. They think it may be slightly warped [emoji53] . The rims I bought are used.
08grey
I would run a lil more air pressure. Try 45 min.
