New 275/60/20 BFG A/T KO2
tsltrek
SE PA
what pressure are you all running in these? mine are at 36 and its a little bouncy
njracer
I'm running 46psi and the ride is fine....plus it's helping a bit with the MPG.
BTW, I love theses tires in the snow!
tsltrek
SE PA
I did the chalk test and 42-44 seems to be a good pressure for me...not sure what was up with the bouncing...rides fine now.
Got a set of 275/55/r20 today. I have about an inch leveling kit. The back sits .25" inch taller. Looks perfect with stock size tires with the new tread and no rubbing.
Ditch that front valance!
Does it look good? I thought it would make it look unfinished. Can't you see the holes where the clips went? I thought about trimming it up to look like the new Denali valence.
Jonah52
Senor ******
Cleveland
You can see the holes if you're really far away, mine is black so its not bad. Looks a lot taller from the front
I really want to take it off. Does it serve a purpose?? I know it's supposed to be for aerodynamics to keep the engine cooler. Being that my truck just hit 100k I don't want to risk it getting too hot all the time, especially in Louisiana where its hot as hell... But I actually do take the Denali off road, so it would be helpful for that, and I cant imagine it helps that much. Someone correct me if I'm wrong. I'm also considering putting a 1/2" inch lower mount leveling kit to raise it up just a bit.
Elliottelias
