New and happy hybrid owner (2013)
C
CYKBC
Do u recall if it is a pain in the arse or ez to do with just hood open?
Sent from my BlackBerry 9900 using Tapatalk
THE YETI
Director of Operations
South FL
Open hood. On top of lamp. You can use a flathead screwdriver to adjust
soulsea
Bar
I'm sorry bud, I actually never adjusted them mine so I'm embarrassed to admit that I have no idea where the adjuster is ... I'm sure someone with a Tahoe/Suburban/Suburban must knows.
---------- Post added at 09:58 PM ---------- Previous post was at 09:56 PM ----------
What he said ^ :)
Be careful not to turn it too much or too fast or else the adjuster will pop out of the thingie inside the lamp.
C
CYKBC
Many thx gents
THE YETI
South FL
Off topic, but I adjusted mine Serge after we spoke. No more blinding people. LOL
C
CYKBC
What r the oem height specs? 25 ft away from wall.....
---------- Post added at 07:08 PM ---------- Previous post was at 07:03 PM ----------
I see a white plastic thing but it's in the shape of an allen head. This it?
soulsea
Bar
http://www.hidplanet.com/forums/showthread.php?10848-HOW-TO-aim-HID-headlights
You can aim them a tiny bit higher because of the rake of the truck ... if you're on 35W you should be okay.
If you want I can go out tomorrow and measure how the oem escalade ones are aimed.
@Robbie: :Handshake:
---------- Post added at 10:20 PM ---------- Previous post was at 10:11 PM ----------
Damn it, I just realized that thread doesn't have a height adjustment measurement ... I'll try to dig up the right thread, otherwise I'll just measure myself tomorrow.
---------- Post added at 10:22 PM ---------- Previous post was at 10:20 PM ----------
In the meantime, for reference, this was my aim on the HyHoe:
25ft/30ft:
15ft:
C
CYKBC
thx for your continued display of generosity serge!
the real test is how the headlights hold up over the months and years in rain, snow, sleet, hail, hot summer sun.
my initial impressions are that YOU GET WHAT YOU PAY FOR. blackflames is now www.performanceautosolutions.com, fyi. i find these to be of real value for $1060 shipped. turnaround time was a couple of weeks. they were very responsive to my emails and took a phone call or two. the connections are true plug and play with no splicing required like some other headlights. i visually inspected them and i saw no smudges and the shrouds are perfectly aligned side to side as they should be. heard no rattles with the shake test and the chevy tech said they fit just as well as the oem units they replaced.
as a bonus, it looks like the performance guys added this extra detail. in the area where the shroud meets the actual opening there's some type of texture like angel eyes except they're not (whew as i can't stand them!). it gives it a bit of a halo around the projector lens - subtle and keeping it oem discrete.
the lighting spread isn't as good as on my other rigs which come with factory HIDs which is to be expected. the flicker, however, is more intense. i don't want to get on my soap box, but 4300K is the ONLY way to go. the whole attraction to the HID setup is that in up-down movement while vehicle is in motion, the mix of colors from violet to magenta to ice blue to sunlight white is what makes it so alluring. when you go anything above 4300K, you have a constant blue which takes away from the overall visual rainbow effect. it also plainly looks non-oem to the discerning eye. so pls stick to 4300K as it throws out the most lumens and your human eyes work their best at this color temp. /soapbox
bottom-line, i'm very happy with them and i can now say i'm officially done modding my truck.
thanks so much guys! hope this helps somebody in their purchase decision and keeps you from going the ghetto, disgusting pnp route (just my humble opinion).
soulsea
Bar
Wow, that's pretty impressive alignment considering they weren't retroed with your truck there.
Congrats! :)
C
CYKBC
Congrats! :)
thanks to you guys, i picked up an allen wrench set on way home and performed the adjustment myself. it took a good amount of turns and was non-linear in the way that it went up and down, but eventually got there :head3:
they're probably a bit higher than oem but not high enuff to blind a sedan on level ground. i want to be respectful! safety first.
Nemo_B4
