New denali new member
Mr. 960
how did you rebuild the mirror? Is it a power fold? I'm pretty sure GM does not sell the power fold motor. Did you just tear into it?
Thanks for the welcoming guys!
Just rebuilt the drivers side mirror today and replaced the key fob cases. Now onto removing the aftermarket alarm..... Hate those things, don't now how many times vehicles have been towed into my shop with no start conditions all because they bought the cheaply alarm.
Talked with the guy that was recommended for rebuilding the board on the instrument cluster and so I plan on sending that off the first part of the week while I rebuild the front steering and realign it.
Gotta retune it soon and firm up those lazy sloppy shifts in the trans. No wonder they burn up lol
I
Izcain
Yea glass was broken and found some poor contacts in the motor that moves the mirror. I just pulled the mirror off and since the glass was already broken I just went at it lol
I
Izcain
Its at the detail shop now and I will post pics next week of the before and after finished product lol
I
Izcain
Well guys here is the pics. I will get the before pictures up in a little bit. It was definitely a diamond in the rough I think lol
I
Izcain
I think it would look good with a nice gm performance intake and corsa exhaust! :rocking:
I
Izcain
Just to put this into perspective lol
New inner and outer tie rod ends
pitman arm
idler arm
new sway bar bushings
new brakes
flushed transmission (royal purple atf)
changed oil, plugs, wires, air filter
Valve cover gaskets
1 tpms sensor
Auto ride compressor
repair rear airlines
serviced transfer case
serviced both front and rear differentials
alignment
flushed coolant
flushed brake fluid
flushed power steering fluid and hydroboost
replace drl lights in front
rebuilt instrument panel and installed white led lighting
replaced passenger side blend door acuator
charged ac system (was just a touch low)
Drivers side mirror glass
Upper heater pad for drivers seat
going in on monday for tint. 20% to make it all match. I think I just about have it under control now lol
TxDrewski
Potomac,MT
Welcome and nice work! Any particular reasoning on the Royal Purple ATF fluid?
Ive been debating that or AMSOIL for my trans after I get it built.
Dnozgodlike
