New from Kentucky
Kosherpotatoes
KY
Good Afternoon all,
Recently purchased 04 Yukon XL. Has high milage and rear main seal leaks a bit. This is gonna be the family driver/trip/ and small trailer puller on occasion. Glad to be here with you all.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon. Please post pics of your rig when you get a chance.
Miami-Dade
Super Moderator
Good Afternoon all,
Welcome from Miami Beach Danny. Check out the 2000-2006 section for any issues you have.
I have family in Morehead KY off State Road 32. A lot of nice people in KY.
Welcome to the Forum from NH.
Pics, please.
Welcome from Oregon. Before you replace the rear main which is a huge job since you have to pull the trans, make sure it’s not one of the other areas that are known to leak and make it look like it’s the rear main. Rocker cover gaskets, oil pressure sender, valley cover gasket can all leak oil down into the same area as the rear main. Oil pan gasket and oil cooler block off plate/ oil cooler lines on the side of the pan also are known leakers. Did you manage to get a borescope up through the inspection plate in the bell housing to see the area around the rear main?
TheMfnManTJ
Another Ky resident here from Hopkinsville. Welcome and these are some knowledgeable, helpful people.
AustinC
