see if you can bump it up another 5 psi on the first number to ballpark it and be absolutely sure you valve cap is clean inside with no damage inside either and do not over-tighten it. Call your self good for now and keep an eye out for leaks. Always run your compressor for a about 10 minutes each week to keep the system in good shape.
---------- Post added at 06:47 PM ---------- Previous post was at 06:36 PM ----------
BTW your cycling rate is in a good area as well.
---------- Post added at 06:47 PM ---------- Previous post was at 06:47 PM ----------
you should get about 8 a minute while idling.
---------- Post added at 06:51 PM ---------- Previous post was at 06:47 PM ----------
If you are not cycling about that much when idling you charge may be getting low. If it stays on continuously not matter how hot it is, that will be the sign that it is time to go back in and find the leak
Dont mean to hijack but I have to ask, the compressor is supposed to go on and off? As far as I know mine stays on. I will have to check tomorrow. When you say 8 minutes, run for 8 minutes? Then how long off?
