Hello from Texas! I just picked up a really tidy 2005 Yukon XL with about 135k miles on a 5.3. The previous owner seems to have taken great care of it, with a log book full of regular oil changes. Paint and interior are immaculate for the age.
When I got the car, oil pressure was showing zero at all times. I figured it was the sender, and sure enough, I replaced this and started getting a reading. I then got low (10 psi maybe) at startup, but when driving I got just under 40. All along the car has had a faint but noticable knocking from the lifters.
I decided to go ahead with the pickup tube o-ring replacement to see if I could get it more consistently higher. When I pulled the pan, I recognized that somebody had likely done this fairly recently. The pan gasket looks fresh and the o-ring was red and flexible, not brittle or mis-shapen. Coincidentally the cross brace with the 4 big bolts that would normally block removal of the pan in a 2wd model is completely missing!
Anyway, I went ahead and replaced the o-ring and put everything back together, including a new filter and 6 quarts new 5w-30.
I now get a low oil pressure message and zero oil pressure on startup. This is accompanied by more noise from the engine. Naturally I haven't run it, just started twice and come straight to the forums.
Does this sound like the pump needs priming after removing the pan? I haven't messed with the pump. I'm reluctant to start the car or rev it until I have rectified this.
