New Headache with the hoe
calvert
Lubbock, Tx
i was going to work this morning and hit a big ass pot hole.. something arced, and now i have no dash lights, low beams, no running lights? I only have brake lights and hi beams... any ideas.. i checked all my fuses and they are all good, im thinking a relay? maybe?
retorq
Kingman AZ
Could be something in the column. Sometimes my airbag light comes on, if I tilt the wheel all the way down it'll go off. Low beams will go in and out too randomly when playing with the tilt ... :(
young_2010_chris
had that happen on my 98 z71 and it was the turn signal swith check relays first tho
maddust
same problem
I had the same problem and after blowing a dozen fuses finally found a bare wire on my front park light that was rubbing on frame.
cody08
Kansas
These trucks are bad about the multi switch getting loose or just going bad all together.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
How about truck year and model info please?
Adamd913
