New headlights for 07 Tahoe
RichardCranium
Mebane, North Carolina
Did you change the main H13 bulb to LED? Not sure if you meant that. If you did, that's not only illegal, but the light output sucks even worse than it already did.
Everyone just needs to do it right and do it like this. Hands down.
http://www.tahoeyukonforum.com/threads/new-bfc-retrofit-headlamps-installed.89909/
Not really applicable here, if you read the OP he has a Tahoe. That is, unless BFC will do Tahoe headlights for this body style (it isn't listed on the site).
And are you in New Mexico also? Since you say that swap is illegal....
To the OP, if you have $100 to spend freely until you ultimately decide what to do with your headlights, do yourself a favor and pickup a set of these from Ebay. I've purchased 2 sets now, and have been 100% happy with them. They truly fit like OEM, and look the same. You aren't going to really gain anything from headlight performance, but your truck will look 10X better with fresh, clear headlights. I've got one set to use while modding another pair for a true HID retrofit (Mirimoto D2S 4.0 projectors). There is a thread in my sig if you're interested in reading it, I've run into some issues with the retrofit. Biggest being our Tahoe headlights only have one adjustment.
https://www.ebay.com/itm/Headlights...vy-Suburban-Tahoe-Avalanche-New-/371040328926
gpracer1
Phoenix
What is this "illegal" you speak of?
I installed LED bulbs in my 13 tahoe and the light output is great, same cutoff as the OEM bulbs.
Now if you are talking about HID bulbs, that is a different story as the low beams have no cutoff therefore causing glare, which is why they must be in a projector housing. The LED is different, it goes in a stock headlight.
20 minutes with a Dremel tool to remove some material where the LED fan/heatsink hits the metal and all is good.
deswilmington
