New member first post. Just purchased 2020 Tahoe premier .. does anyone recommend mid grade or higher octane fuel for a 6.2 liter?
Smartmoney1971
New member first post. Purchased 2020 Tahoe premier 6.2 liter.. does anyone use mid grade or higher octane for theirs?
lbenson
I always use highest at the pump.. 91, 92, or 93 depending on the station. Says to use minimum 91 on the inside of the gas cap. Worth it in my eyes for the longevity of the engine and the better performance (power and fuel economy).
If no ethanol is available I always use that too.. have found I get slightly better MPGs and the engine runs smoother.
S
Smartmoney1971
Thank you, guess I should have read a little longer into the manual. Just purchased this on Tuesday, and had no time to check on anything
There is a recent long thread with folks opinions on gas grades to use for their trucks, particularly the 6.2 engine. Someone here may find it for you and post the link.
BauerTahoe
I agree with using a premium over a basic fuel. I have run all option and premium is “smoother” I find.
Geotrash
Dave
Richmond, VA
The compression ratio on your engine is 11.5:1. That's firmly in premium-only territory. Lots of examples of earlier 6.2's (with only a 10.5:1 ratio) eating eating a piston under load on 87 octane fuel. Your engine has knock sensors that can help protect the engine from pre-ignition with low-octane fuel, but as many here have learned (and have the data to prove), the system isn't perfect and can't fully protect the engine under load.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum and use the recommended fuel listed in manual. Higher price for the top grade but engine longevity is worth it.
BreBoyz
