New problem with tail light
blizz
San Antonio, TX
Now it's the passenger side. I get nothing, no brake, no reverse, and no signal. All bulbs are good. I took off the working driver's side assembly and plugged it into this side and got nothing. When I push the pigtail in really hard and hold it in, one of the filaments barely glows red with the brake pusheddown. Anyone have any ideas? I'm thinking of replacing the pigtail.
Bigbody250
Clean the contacts up, check with volt meter... If you don't have a volt meter just bend ya a paper clip and stick it in there with your fingers, you'll know then
noJeepshere
Bountyfull, Utahrd
:lol:
Bad tip of the day!
I've heard that the circuit boards/plugs go bad in these things over time, especially if you live in a corrosive environment.
_Dylan_
STAY FROSTY
Try taking the connector apart and adjusting the pins for better metal-to-metal contact.
omg no
Go down to harbor freight and get a test light for $3.
blizz
blizz
San Antonio, TX
Ok so now I have NO brake lights on either side but do get parking lights. When I turn signals on, they blink really fast. Also, the third brake light does light up just fine when brakes are used. What gives??
Bigbody250
When mine was acting funny I had to change out the circuit boards and all the bulbs... The old bulbs in the new board did funny stuff like your saying. They weren't burnt out and looked fine but didn't work.
blizz
blizz
San Antonio, TX
I bought a new brake light switch and will buy new bulbs and see if that does anything. It's hard to believe that I have a bad switch if the third brake light comes on but who knows. I'm slowly starting to think of getting rid of this thing.
crxx
tn.
i bet its the $10 brake pedal switch..... i had the same issue and that swtich was the problem
blizz
blizz
San Antonio, TX
If the switch is where I think it is it looks impossible to get to and replace. I'm not looking forward to it
bobwass
