New Ride! Need some (lots of) assistance...
nimrod.sixty9
Hold on, I got this.
Okeechobee, FL
Just picked up a 96 Tahoe on a trade;
1. Didn't come with a key fob. Do they not come with keyless on 96's? If not, can one be removed from another donor truck?
2. A/C is charged and most all has been replaced by previous owner. Compressor still doesn't kick, though he did say it worked fine, just stopped. How can I test high and low pressure switches? What else?
3. Vibration at 70. Brakes seem really good, no vibs while braking. Tires, balance or could still be rotors? How could I test?
4. Steering seems loose. I think some could be due to the speed sensor, but it seems really loose no matter the speed. Someone point me to the link that shows how to tightening up the steering box? Suppose I should be inspecting the idler and pitman arms...
5. Any tips on taking care of roof rust? Clear coat on hood? See pic
6. Power steering pump explodes fluid. Is this a clogged line or just replace the whole pump? Steering is easy when it still has some fluid in it. I'm sure I answered my own question, but I've never seen it do this so it couldn't hurt to just ask.
7. Power mirrors, each side only works in random directions, if at all. What causes this?
8. Power seats, some directions work, some not. Some work, but slow, and some work great. One I find strange is, the passenger moves forward, but not back. Isnt this the same motor?
Gzes
the drifting 2dr
Wichita tx
sand roof and spray. very easy to do. hood just wet sand it and re clear. i use rustolium clear
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
Do I have to get all the clear off or just smooth out and repaint. Repaint affected areas or have to do whole hood. Im decent at spraying, not so much as prepping.
Gzes
the drifting 2dr
Wichita tx
depends on you. can probably get away with just wet sanding all the white and clearing then buffing but might show the lines where the white was
inthechateau
Maryland
I've been running a 96 4dr LS Tahoe for last 10 years and have over 300K on it now. Let me see if I can help with your questions:
You can pick up any FOB and program it to your Hoe. Instructions can be googled or pick up a FOB at the parts store and they will do it for you. You do not have security coded key in a 96.
If you are not familiar with AC component testing best leave it to a shop that has all the equipment to test pressures. It may be over charged and high side sw is interrupting circuit---on purpose
If it is rotors it will be most pronounced while braking. If VIB is only while driving high speed most likely tire balance. Rotate front to rear and see if it changes.
I'd be checking all the front end parts really good before I went hauling A$$ 70mph down the road on a used truck. Not sure how many miles you are tracking but I have done all the components twice in life of this truck. Adjusting the steering box play out can messs you up if you try to get it too tight.
Sorry, got the same problem and I am going to take it to a body shop when I get home from my deployment to have a full make over done on the paint.
Sounds like a bad check valve or some one put a filter inline and it is clogged. A new pump will fix it-cheap fix but you'll need a steering pump pulley puller.
Dirty control switch, take it apart and clean contacts or just buy a new switch assy.
Motor contacts all nasty from dirt and dust. You can clean them up but you'll have to pull the motors out. Also check the switches for good contacts. Losts of stuff gets shoved under the seats and could have partially unhooked the connectors or broke a contact.
Good luck on your project and post some pics when you can.
Y2KpewterZ
I programmed a fob from my 99 Tahoe to my OBS 00 ..
1. Locate the DataLink Port. It is located under dash drivers side. Be sure you know which pins are 8 and 4. (Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable jumper wire (paperclip) (leave the jumper wire connected throughout the programming procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be programmed. After about 15 seconds,the vehicle will respond by locking and unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous stepon the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
Some food for thought.. the relay for my A/C compressor was going/was bad causing the compressor to have a mind of its own.
And for touch up paint I would recommend automotivetouchup.com
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
Appreciate that, but I already know how to program the fob. I wrote the write up in the tech section on it ;) (see sig).
What Im asking is if it has the equipment to accept a ky fob for keyless entry.
---------- Post added at 11:50 AM ---------- Previous post was at 11:24 AM ----------
See above. I want to know if it came with it, or if it didn't, can I pull off some component from a donor vehicle for said keyless entry.
I am familiar with most. I even have all the equipment. This is why I ask, so I wont be taking it to a shop.
I will try rotating. If it doesn change?
There's a link that shows how to properly tighten the steering, thats what Im looking for. She's got quite a bit of miles, 170k I think. I do need to get under the truck and start checking. Usually it would pull or have abnormal tire wear if something is way out. I didnt see this so didnt I didnt assume it was in too bad of shape.
Im going to try what Gzes recommended. I like doing these things myself ;)
This check valve is it the pump itself or do I need to replace lines? So you know, it does work, just slowly starts spitting it out. Why do I need a pully puller? Im prob going to pick up a whole unit from the JYard (they are dirt cheap).
Oh I hope its that easy! Will check this. So worried it's the mirror motors, whereever they are.
So take out seat and inspect first, got it lol. Anything recommended to clean with?
Will do and much appreciate the assistance!
kcb37
RPO code for keyless entry.
AU0
Rotate the tires. Does it feel like it's in the steering wheel, or floorboard/seats?
If in the steering more then likely front tires. Floor board, rear tires, rear driveshaft/u-joints, front driveshaft/u-joints. If 4wd you can pull the front driveshaft. If it stops we know what it is.
Steering 96 has no speed sensor (evo system) that was 97 and later so that is out the window.
Key on engine off. Lay under the front have someone turn the steering wheel. Not the tires just the slop in the steering wheel, so very little pressure. Look for what's moving.
Colum moves, gear box out put does not, gear box is bad. Gear box moves, pitman arm does, center link does not, pitman arm, etc....
If the gear box is bad you are better off replacing then adjusting.
The fluid I would agree is more then likely the check valve in the pump.
The mirrors more then likely the mirror switch.
Got one from the junkyard for my 96, wifes 99, moms 95 S10 Blazer. You would have to look but I would be willing to bet a fullsize and Astro van are the same switch. So you have a lot to look at in order to find one. Problem is these break so they get picked up kinda quick.
Before you take one, even without power, press the button each direction. If it just kinda flops down/does not click it's bad. (no promise it's good even if it does)
Got all 3 for $10 or less. New is $60 or $80. May take some time but in the mean time you can manually push the mirrors.
Seats I would agree with above.
The rest, not something I really have done or do, have some more to learn.
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
I do have said RPO code. Yay.
Also, got the locks to respond by jumping pins.
Then to find out the fob I have must not work at all.
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
Now I have white smoke. Hot or cold. Seems to clear up once it ran a bit. But would give a puff after revving and releasing.
What do I need to start checking?
Remember, I don't have this on the road. So how long should it take to see a difference in water level (assuming I will)?
NinoRiojas
