New throttle body - Limp Mode
M
mikelouf2
Also check your grounds. Especially the driver's side frame, right near the running board. A known issue, especially for guys in the rust belt.
I put a new plug on I think the Amazon junk. It keeps make noise every time I put the key on or when I hit the gas pedal going to return it and get the acdeco they have on there
Electrical noise? Did you replace 1 wire at a time? Since they're all white wires--not color coded. What brand tb did you get?
M
mikelouf2
Yes 1 wire at a time. I took the throttle body off I put the old one back I can getting run put is running rough. Acdeco throttle body is coming in a few days
15burban
Wisconsin
Check the seller on Amazon even if it says it's an ac delco. A lot of fakes out there. Personally I would only buy online from rockauto or a gm website. I'd rather pay more then be ticked off when the new part doesn't work or work as advertised.
M
mikelouf2
Ok thanks I check into it
Ja1034
