This car is awesome. The thing heats up under load though. Hauling a 4k lb trailer on the freeway, uphill on a hot day at low RPM gets the engine heating above were it usually sits. Performs better at high RPM, and has no issue at lower speeds, say 45 mph and bellow.
The oil change tag says 5w-30 was put in. I see 5w-20 is recommended.
Also, it appears an aftermarket air-intake has been installed.
Could the oil heat up like that? I see thicker oil heats up an engine, but as it gets hot it should get thinner.
Where should I start troubleshooting?
