tbgrey2007
- Joined
- Oct 20, 2022
- Posts
- 20
- Reaction score
- 15
2007 Chevy Tahoe developed an intermittent engine/tranny problem. The vehicle cranks and idles fine, but does not seem to respond to the throttle, rpms will not climb and vehicle lurches, like the throttle response is really delayed and limited. Local shop changed the throttle body and it ran fine. I picked it up and did not make it a 1/4 mile before it started again. Took it back and ended up putting in a remanufactured transmission. Vehicle has 230k so I figured that was coming. Picked it up, drove about 10 miles home, no problem. It sat for a day or two. I went to drive it and the same problem started again. Had the vehicle towed back to the shop and it ran fine on a test drive. Mechanic took it home and the next morning the problem started again (at least they see I'm not making it up). I checked the V4-V8 mode while it was misbehaving and it was show in V8 mode, so I don't think it is the AFM acting up. Shop has been looking at it for several days and seems to be stumped. Had a motor mount changed several weeks ago. Wondering if something could have gotten pinched during that process (wiring or a fuel line). Throttle position sensor checks out. I asked them to check the fuel pump and catalytic converter (maybe it is clogged up). No idea where to go from here. Thanks.
