Haha.. thanks for the tip. I will carry special 2x4 in the truck. That is a good thing to know in case i gets stuck.
yukonxl04, thanks for the heads up on filter and pump. I will look at records and perhaps change out the filter. I can't imagine that filter is that expensive...
I drove it home last night. We had to jump it. the battery, brand new, was down to 2-3 volts. It jumped fine and showed it charging. if you accelerated, you could see the amps move. When it was home, 30min later, i turned it off, and it showed about 12 some volts. It started up again sluggishly.
The hitch outlet on rear bumper had a tab bent, but it did not seem to be touching others so I don't thinks this was issue with drain. I bent them back.
The cluster came back on and was working fine. I had no single dead gauge and all seemed to be working fine. PO said when it dies, it goes completely dead... whole cluster off. Cluster had been ongoing thing for many years. when they took it to dealer, it always worked fine.
PO said no additions had been made recently. Only aftermarket item is a dvd player for rear, added in 2004 by dealer.
I did not have time to check it out last night, but i will do so hopefully tonight. I will start by looking at records to see what was done recently, to see if perhaps a mechanic shorted out a wire.
