NHTSA opens preliminary probe into more than 870,000 GM vehicles
jfoj
Believe it or not, a lot of these larger SUV's (Tahoe, Suburban, Yukon, Escalde) are driving by what we often call "Soccer Moms" what you might call "Football Moms", mothers of 2-4 kids ages 4+ years old that are constantly on the run 7 days a week; running kids and friends to school, appointments, sports, social events and so forth. The moms really tend to put the vehicle thru pretty severe duty other than towing, very similar to commercial use. Rarely any long highway drives unless the family travels, which may only be a few times a year. No disrespect to the "Soccer Mom", love me some "Soccer Mom" but I have witnessed this first hand over MANY, MANY years while my son played many sports, while working on vehicles and being around many of the husbands of "Soccer Moms".
You end up with the following:
Lots of short distance runs where the engine may not fully heat up
Auto Stop/Start is not likely manually turned off unless the husband bypassed this feature
Mostly in town, city traffic with a lot of time sitting in traffic and/or at traffic lights
DFM not likely bypassed or transmission kept in L9 unless husband installed bypass
Lots of remote starting and allowing the engine to run a long time to warm or cool cabin
Lots of extended idle time to keep cabin warm or cool in carpool lines wait for kids
Extending oil changes out until the OLM pops on dash, then maybe longer
Rarely checking the engine oil, that is what a sensor or light is for!
Unfortunately these conditions are quite common and the vehicle and engine will be tested just due to rat race schedules and needing to haul kids to every event known to man and usually running a tight schedule, barely being able to make an event on time.
I would love to know the engine run hours as well as mileage for most of the early engine failures.
Agree with your comments about the oil pressure being a bit late to the game, the sensor is in the front of the oiling path almost directly after the oil filter, in the old days this was fine, but now with all the DFM components and the fact you have a 2 stage oil pump, having an additional oil pressure switch at the end of the oiling path to control the 2 stage oil pump would have been a novel idea!
As you are aware, I raised the issue of oil fill level when changing the oil, there is an entire thread of hate about this. I have carefully monitored the oil level required when changing the oil and filter and it is MORE than the specified 8 qts, even GM stated in the earlier generation engines the oil fill capacity as 8.5 qts, then sometime along the way with printing of a piece of paper and no changes to the engine or oil pan the value was reduced from 8.5 pts to 8.0 qts and has been this way for close to 10 years.
I myself have decided for many reasons, to include all these engine failures, torun 9.0 qts when changing the oil and filter. I do pull the dipstick and remove the oil fill cap when I drain the oil and allow the engine to drain for close to 2 hours. 9.0 qts is slightly above the top hash marks on the dipstick, but nowhere too high where the crank will hit the oil. Keep in mind while the engine is running, there is oil that has also not drained back into the oil pan, just check the oil when immediately turning the engine off vs waiting 10-60 minutes to check the oil. Have your guys take a spare oil pan on the bench and fill with 8 qts of water, mark the level inside the pan, then add 1 more quart of water and see how little the level rises in the oil pan. You would probably need 12-13 quarts in the engine before the crank would be hitting the oil, at this point the level would be above the windage tray.
The additional 1 quart gives a slight edge on fuel dilution, oil cooling, overall contamination, if running oil until the OLM/OCI triggers, having 1 extra quart means the oil will be overall less contaminated for the same conditions at 8 qts. It also gives a much larger buffer for people that do not regularly check oil before the oil level gets to the point the Add Oil message pops up on the dash, which is typically when the engine is 2 qts low on oil.
Anyone with a newer model DI vehicle that runs on E10 fuel that wants the engine to last should be changing the oil at 1/2 the OLM/OCI. In most cases this would be around 4000 miles IMHO. But it also depends on the oil sump size as well, if a smaller turbo charged 4 cylinder with a 4 qt oil sump, I would not run past 3000 miles on an oil change these days. We have kind of stepped backwards to the 1960-1970's for oil change mileage, but it is due to all the technology but we have also harnessed a lot more performance and efficiency out of todays engines, but with far more moving parts.
Vladimir2306
Exactly, I remembered)) I just wrote in your thread that we fill almost 9 quarts of oil, instead of the required 8 quarts according to the manual)) As for the statistics of early engine breakdowns, for us it’s from 500 to 10,000 km approximately.
Further problems are only due to the lost oil level.
But there are a lot of cars that break down at low mileage. Against this background, owners began to think about buying a 5.3 or 3.0 engine, and we are also waiting for deliveries from China cars with a 2.7T engine, yes, small, but not serious on such a car, but not a real American V8, but it’s better to have a 2.7T, but one that runs, than a 6.2 that breaks)
DontTaseMeBro
As I understand it, you’re talking about remaking the standard Yukon headlights? :) yes, there are some interesting threads of mine there))
We have a small circle of fans of the brand, plus we communicate personally with GM services, there are not many of them. Since services welcome any sources of information, this is a closed chat where service owners and representatives communicate. So, it was their information that I conveyed.
There are three possible reasons: the oil pump, defective connecting rod bearings, and insufficient temperature clearance. As I said above, version 3 is closer to me. But just like with the oil consumption, which I partially corrected on my Yukon, I suspect there could be more than 1 reason.
Yes sir. That be the one. I'm still hopeful that someone can offer the means to convert the headlights here stateside.
jerry455
Good, better than 0W20.
So some questions:
What year vehicle?
Did you buy vehicle new?
Is this the original engine?
At what mileage did you start with 0W30?
How many miles do your change your oil or do you follow the OLM/OCI?
Any oil consumption between changes and how much?
How many hours are on the engine?
Do you use the Auto Stop/Start feature?
Is the Auto Stop/Start feature bypassed?
Do you have any sort of AFM/DFM disabler?
2021 Suburban, 6.2, used last May with 70,000 miles on original motor. I switched last oil change. I usually run 4,000-5,000 miles or 25% oil life. I do not loose much oil between changes at all. 2,100 hours. Sometimes I turn off auto stop, neither Auto Stop or DFM is disabled.
Vladimir2306
Well, or I try to send the kit for installation in the USA. But taking into account the shipment, it will be, I'm afraid, not a very cheap story (
jfoj
"I switched last oil change"
Does this mean you change oil from 0W20 to something else?
Thanks for reporting in details.
nomech
Senior Member
another article....
"a 2025 Chevy Suburban—so that she can operate while she waits on a new engine. Her fingers remain crossed that the 2025 model year has been spared the same issue that sidelined her 2023."
I thought the 2025 5.3s (lifter) and 6.2s (bearings) are still vulnerable?
PPK_
Oklahoma City
Reading all this.. if clearances are a problem on pistons… it seems to me that a 207 deg was what 2018 l83 had… is that still what it is on the 2024s? I know you get down south.. the gm cooling is weak..
jfoj
I think my 2024 typically run close to 204F, need to check and see if this is the number.
bobbywdatool
