NHTSA opens preliminary probe into more than 870,000 GM vehicles
WalleyeMikeIII
Sunny and Snowy Minnesota
LOL, first you're daugheer is probably wearing the pants in the relationship if her fiancé is driving a Prius.
Second, yeah,, you do realize that Prius engine doesn't make anywhere near the torque of a 6.2 right. So its not trying to push the thin out out from between the bearings near as hard as the big V8.
Could the thin oil work in the bg V8, yeap it sure could, if (and only if) you fed enough volume at sufficient pressure to the bearings, but the oil pump is something else they cut a bit on the 6.2. So the options are either replace the oil pump or run a thicker oil.
LOL, their relationshp is fine...they are both super frugal, so he willingly took the hand me down from his mother...
Yes, I know HP in the 2.0 Honda 4 cyl is 200, and in the prius is smaller than that...
The poster said "he would not run 0W20 in a modern engine" and my point is you can run it reliably in a modern engine..based on these examples.
BTW, the HP/CYL of the Honda is actually on par w/ the 6.2, and higher than the 5.3....torque per cylinder is a similar story...so if you break it down to force between rod and crank...the story may not actually be all that different...right?
We are kind of stuck in a situation though...while 5W30 Dexos might actually help us...if we blow the thing in the powertrain warranty...and they come back and say we didn't run the recommended oil...do we get a warranty replace on the engine? It is a pickle.
blanchard7684
Senior Member
Sommerfeld relation to eccentricity ratio would strongly suggest that the 6.2 needs a higher viscosity.
The RPM/load ratio (Omega/W) would support moving the eccentricity ratio away from 1.0 which is technical contact between journal and bearing.
This relation is standard relation for bearing design. It is solved iteratively to find the eccentricity ratio required to generate a hydrodynamic film of sufficient strength to balance the applied load from the journal (a reaction force)
You want to avoid being on the extremes of this curve.
For high load and low rpm operation, adding viscosity (the "u" term) will keep film strength such that the eccentricity ratio won't be near the .7, .8, .9 range.
The 5.3 can get away with the 0w20 because it operates at higher RPM for the same load. The hydrodynamic reaction force generated at this rpm is sufficient to balance the load and doesn't need added eccentricity to generate this reaction force. Thus 0w20 can work here for a 5.3.
Even for a 5.3 it is probably sketchy when you throw in longer OCI and fuel dilution.
The 3.5 ecoboost runs a 5w30. That is a heavily loaded bearing at full load. Not sure if the ecoboost is running 1200-1500 rpm at highway speeds.
All this is assuming there isn't an issue with jaw fits, bearing crush, and journal taper issues on the crank.
KMeloney
100% YES, absolutely.
The short block and rotating assembly is identical, part number for part number, between the base Corvette 6.2 and the truck 6.2 ( camshaft has a different grind though). Guess what weight oil GM specs for that ,,, spoiler alert ,, it isn't 0W20.
Mobil 1 even came out with a GM dexos approved oil just for this, and its available at most regular autoparts stores.
What are you running in your '23? (And you've got a 6.2 also, right?)
KMeloney
I think the 6.2l is a perfect storm of a number of issues. There were clearly some part problems, but these should have been flushed out a while ago. The lifter bore issue, assume this was resolved.
A while ago as in WHEN? I've got a '23, which is specifically referenced in the Customer Satisfaction engine-replacement memo. If I'm sitting on bad parts, then it is what it is. But if I can stave off a failure with a change in oil type, then I'll do it.
jerry455
If you are under the warranty, I would run what is recommended. Mine is out of warraty so I am running 0W30 in my 6.2. I may use 5W30 in the summe.
Antonm
Yes is a 6.2, currently I'm running the dexos rated 0W40 Mobil 1 oil (figured I'd give it a shot to see what the oil sample looks like), but I've tried the 0W40 euro spec Mobil1 and the 5W30 truck & SUV Mobil 1 (right now the 5W30 truck & suv mobil 1 is looking pretty good though)
While I like Mobil 1 obviously, there are plenty of other oils out there that are just as good, oil brand really isn't all that important. All of the premium synthetics are on Par with each other, run whatever name brand you like.
But here are two oil samples , one at 6K total miles on the engine (3K miles on the oil) with 0w40 euro spec mobil 1 and another with 12K total miles on the engine (6K on the oil) with 5W30 truck and SUV mobil1. I don't have any other sample results on this computer (my work computer), but the others look similar as far as wear particle count goes . And as long as its under 5ppm combined wear particles per 1K miles driven, I call that good.
6K miles on engine (8 ppm wear particles/ 1K miles, little high, but the engine is still breaking in at only 6k total miles)
12K miles on engine (3.8 ppm wear particles/ 1k miles, which is good IMHO)
jfoj
So here is the deal with running something other than 0W20 engine oil. If there is a failure, the dealer is not going to perform an oil analysis. Even if they did, the higher viscosity would show up only if the oil is not typically fuel diluted. But the engine would not be failing for a slightly higher viscosity oil anyway. Plus these engines have a pretty bad track record anyway so nobody is really going to question a failure.
@KMeloney, my sources tell me there were some bad bearings during COVID 2021, some may have made it into the earier 2022 MY builds, they likely have 2021 date codes on the rear of the bearing shells. For 2023 this was I beleive for the Oversize Lifter Bore problem. I would have your dealer run your VIN. Also get the truck up on ramps or a lift and get a picture of the engine production tag on the rear driver side cylinder head. The engine will have a Julian date in part of the label and you can find out exactly which day and year the engine was built. What is the build month and year of your truck? Chances are the engine may be 2-6 weeks younger than your truck.
There are a lot of things owners can do to hopefully prolong the life of these engines. I think a lot of what is happening has to do more with fuel dilution, oil consumption causing the engines to be run low on oil, extended oil changes (I would not go beyond 50% of the OLM) and not running premium fuel.
After a lot more research and thinking on the overall oil subject and actually speaking with some well known and well regarded people in the lubrication industry, I think the best oil option is probably the Pennzoil Ultra Platinum synthetic. This is due to its higher levels of Molybdenum which is a very good engine oil additive to reduce friction and holds up better under high pressures and high temperature conditions. While this oil is not Dexos licensed, it is partially due to GM requiring the oil vendor to divulge the oil chemistry and ingrediants as well as paying a licensing fee to GM. So many higher end or speciality oils that have an 'edge' over the competition tend to not want to have some of their products licensed to protect their products.
Each their own, I will be running some oil analysis on the Pennzoil Ultra Platinum and as long as the calcium levels are in line with the Dexos oils I am good with it.
If I can run a better oil, higher viscosity that will protect the engine, why would I not want to do this? My goal is to not have the engine sieze if I can do anything to protect it. Pretty simple approach IMHO. I am sure others will disagree.
Jesse729
This is an interesting discussion about the oil viscosity. I could have lack of knowledge here but I am wondering why the discussion is not gravitating more towards the variable displacement oil pump? While it might be complex, could a solution be to defeat or disable the variable displacement have have the pump running at a higher volume?
Antonm
Because we’re lazy and don’t want to mess with the oil pump or its control system when putting in a different weight oil during an oil change will solve the issue is mostly the reason the discussion isn’t going more towards oil pump modifications.
Coop68
