denalianyone
NYBlackLade08
Most gorilla and wheels locks are universal and not unique, just like center cap torq bolts. That's why center caps are easy to remove. U can bring a set of torq bits and remove em. A thief can got up to wheels with a bunch of wheels locks and pull em right off. Most tire shops carry them for cheap. I never said the process of stealing rims were easy but all thieves are determined.
---------- Post added at 05:42 PM ---------- Previous post was at 05:36 PM ----------
That's why they putting cylinder blocks under the brake assembly is so easy because if they remove one wheel without lifting the entire rear of the truck, it will slide right under. And the wheel on the other side is still planted on the ground.
---------- Post added at 05:44 PM ---------- Previous post was at 05:42 PM ----------
The weight of the vehicle is on the springs and shocks if applicable
i dont get it. all the weight of the vehicle is still on the tires flat or now. unless the support if from the height when the tire was inflated?
