Nitto Trail Grapplers Installed
Zed 71
Zed 71
Pacific NW
There was more trimming than I anticipated. Others have installed 285/65/18 BFG ATs with no trimming - actual size varies with each manufacturer. The Nittos were ~32.5 inches in diameter which is close to theoretical 32.59". I had the installer trim, but I should have done it myself (cleaner and they cut the wheel well liner).
The Z71 has different front air dam/bumper. The two black bottom brackets (see picture above) had to be trimmed ~2 inches from the wheel well towards the front. I do take the truck off-road and did not want any rubbing when flexing the suspension. As I mentioned, they trimmed the actual wheel well liner and if I did it myself I would not trim that liner and would have just used zip ties to secure it back to the trimmed brackets (drill holes in the trimmed brackets).
As far as noise, it is pretty quiet for a mud terrain - comparable to BFG ATs. Of course it is louder than the OEM. It has 3-ply sidewalls so they are heavy and you can notice it driving away. Once under way, it is ok. Having thick sidewalls also stiffens up the ride, in a good way IMO. You will notice this right away, I did not realize how soft the OEMs were.
I know someone will ask, the mpg went down of course. I was getting ~16 to 17 mpg in the city, now I am getting ~14 to 15 mpg. No highway use yet. Looking into the BB tune next.
UofMZ71
wow you were getting 16/17 in the city! with my BFGs before the tune i was getting 11! now after the tune im close to 14, makes me happy!
i really like those tires! i waiting to run my BFGs out then get new rims and M/Ts
emann_01
I have a BB tune and I currently get about 17.5 to 18 mpg with mixed highway and in town driving and a pretty heavy foot (BB tune will do that to you)
Thats good to know about the plastic piece on the front that you had to trim.... i plan to remove all of that anyway....even that plastic crap inside of the running boards.
thanks Zed
Arctic-Rodz
RGV Texas
Great tire! I just put those on my 98 yukon 4x4. 295/70R17 with Eagle 140 series.
They did a good job on the sand, i also had to do some trimming. Its a beefy tire.
Zed 71
Zed 71
Pacific NW
I wonder if the 4.10 final drive makes a difference in mpg. You would think the increase in rpm at crusing speed would use more gas, but it seems like V4 mode was used more often (compared with <4.10s).
Emann I hope to have results like yours!
TX nice looking rig. Those are huge tires!
2 E L O
Omaha, NE
^ Thanks! BTW how do you like your Hypertech?
Meh....it's ok. :shrug: I like it because I can change the shift points and "slightly" change the shifting firmness. As far as engine performance and mileage, I can't really tell much of a difference between stock, the regular Hypertech tune, and the high octane Hypertech tune. I leave it set on the regular tune so I can use the cheaper, lower octane fuel. I get around 12-14mpg around town and 16-19mpg on the interstate.
It will also be nice that I'll be able to adjust the tire size when I put on the new (larger than stock) Duratracs so my speedo/odometer are correct without having to send anything in and waiting a couple/few weeks.
I was interested in the BB tune but I just don't think it fits my needs very well. I am also interested to see how all these peoples' rides are holding up in a few years with all the TM removed. I plan on driving this Tahoe until it's dead, so unnecessary premature wear is not really my thing. :)
emann_01
what size Duratracs are you going with?
I have been looking at the 295/65/18.....
but I just ordered a trans for the truck I am building so I have to wait a little while
2 E L O
Omaha, NE
I'm selling my stock 18" Z71 wheels and going with the 17" steel Police Tahoe wheels. The Duratracs I ordered are 285/70-17. Just a hair under 33" diameter...
You'll definitely need a leveling kit and some trimming to fit the 285/65-18s....
Cwoomer49
