NNBS coil-over conversion
Goodinblack
I Like Tacos
Dirty South
Tony been working on coil overs since I been on this forum
Bawhahaha
Jk tony
992dr
992dr
Eastern N.C.
I'd like to see coil overs in the rear!
This is why I started this thread.
The fronts are an easy swap, the rears on the other hand aren't as common.
I would like to use coil-overs as well as TBSS bags for towing purposes.
I have a random question in regards to the links when you lower the rear.
How much out of angle do the links sit after you lower your truck?
Has anyone altered there link mounts to correct the angle after being lowered?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
in the rear you can use a qa1 shock with coil spring on the oem shock mounts but the problem is you will lose area fo rtire space.
What link mounts are you talking about?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
we already hae a similiar set up and i sell all those bars.
would look like this like on my old tbss i set up
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no im working on the fronts at this time.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no because you can use my custom springs and run qa1 double adjustable shocks and be fine in rear.
992dr
992dr
Eastern N.C.
Do you have any info on your set up?
Are there other coil-over options?
What spring rate would you recommend out back?
You don't think it would be necessary to relocate the mounts for proper geometry of the links?
Thanks
tony97218
