NNBS Suburban with 2" drop rubbing
Joew311
Joew311
TX
Yeah about an 1'' higher should be perfect.....exactly what I was thinking lol
It definitely needs an inch. When I have it all loaded down with our bags for a trip the back sets about an inch lower than the front.
justinesky
Tire pressure! My tires do that at 35psi but not at 40.
Joew311
Joew311
TX
Very interesting, I will have to check that out. I also thought about my airbags as well...maybe the pressure dropped in them or I have a cut line or something...I definitely have some things to look at. Thanks!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
this is normal in rear will need to trim the fenderliners. For 2 inch drop i use the 5321 kit its a better spring rate for the rear if you only want 2.
Joew311
Joew311
TX
Good to know, a little too late now, though. It seems to be much better now that I aired up the helper bags.
welfarewagon
Lexington, KY.
Mine did the same thing, only the right rear, I just trimmed off the plastic where you could see signs of it rubbing, didn't have to jack it up or take the tire off, just reach in behind with a razor knife.
ABNLT
LaCrosse, Wisconsin
Mine rubs in exactly the same place. Will have to bend the liner when I put on the summer wheels here shortly.
DarkKnight
