NNBS Yukons with Corsa Single Exit Dual Tips?
soulsea
Bar
There's no space/place to put it anywhere else that I can see ... the pipe from the muffler bends over the axle, then snakes around the spare, to the res. Side exit looks to me to only be possible with a res delete.
So really what is needed is a small slightly S shaped pipe section between the res and the tip to allow the tip to drop below the bumper and exit straight out the back.
Again, that's how it looks to an exhaust no0b like myself. :shrug:
JennaBear
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
The tips I have aren't for side exit (not side slashed), so I was hoping I could get a muffler shop to do a custom install with them. If they needed to relocate the resonator, I would be fine with that, but I am thinking they can just use a new pipe from the resonator to the rear so it would sit straight.
soulsea
Bar
Good deal ... if you figure out what is needed will you have them make two of them?
Thanks. :)
Administrator
That's exactly what sumo had done as well. I'm not sure how different his set up was with the resonator compared to the Denali, though.
soulsea
Bar
That is exactly how I feel. Would totally do a side exit, but I don't want to take off the resonator- I like the quite rumble. Might be doing this soon, worst case scenario, I take it off with the resonator, and redo it with a side exit.:Handshake:
Couldn't wait for ya :) ... it's barely louder than stock:
[yt]j3Pl5RCi6TM[/yt]
Administrator
Jenna, set up Serge with a magnacharger and let's find out!!! :D
THE YETI
Director of Operations
South FL
Certain member has a TVS2300 in his garage for a 6.2. Mwahahaha
Administrator
Donate it to Serge so that we can get info for Jenna
etreanor
