No crank
onelove
Ok so I went to crank my yukon which it was fireing right up but when I went to crank it today I messed up bad for some reason i didn't push the key in to crank it. now I can't get it to crank at all help please.
need a better explanation here.....
pictures?
did you break the key off or something?
is it stuck? if so try pulling on the steering while turning the key in the ignition. If the wheels are turned and it is locked up you need to pull the steering wheel in the direction of the wheels to release the binding.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon.
Your explanation is very confusing. This is not a text to someone used to a run on mix of words. You need more detail and pics.
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving clarifying questions from the knowledgeable folks on this Forum. Give us some additional details and we'd love to assist you in troubleshooting.
S33k3r
Dallas, Texas
More than likely your ignition switch is worn. Something you can try is to try a different key and see if it will turn. I had my Silverado stick in the on position.
Other than that suggestion, the more information you can provide, the more likely you'll get the answers you need.
Shrubb
